ph2 172/bmw compact
Just bought a clio 172 ph 2 basically the problems are
Nocking in first and second, sounds like a rear gearbox mount gone that sort of knock, gear stick moving etc. Read on internet engine mounts are common as muck could someone please confirm this?
Slight knocking from o/s/f sounds like a cv joint. Can you buy the joint seperately on these or is it a new shaft jobby?
Thank you in advance
