Had it on the misses car about a year ago, jacked it up and went over everything just to make sure nothing was loose.
the pinch bolt where the lower arm ball joint goes in to the hub wasn't quite tight, as I tried to tighten it I realised it wouldn't actually tighten up, as tho the thread was pooped.
new nut and bolt ordered, fitted two days later and the noise magically disappeared from that moment.
its worth going over everything to check all nuts and bolts are tight.
