Knocking noise, HELP!
  Red197
Was getting a bad knocking noise in 1st and 2nd. Replaced lower engine mount with a poly-flex bush from K-tec. This has not worked. The noise is now very bad. Any ideas??? Could it be driveshafts? If so would they not make a noise in third, forth and fifth?
Any comments welcome, my local Renault dealer can't decide what to do.
  An orange one
mine does it too, mines going back to renault again on tuesday (3rd time now) to see if its the front pipe hitting the subframe..
  MKIII 138
have you seen the other post where i replied about knocking, anyways il repeat the post in here
i just had this fixed on my cup i know exaclty what you mean, its a gearbox mount under the battery. get it done under warenty other wise its a 2 hour job at £65 per hour and £130 in parts.
also dont cane the car until its fixed.
hope this helps.
