First thing I'd check. Mine come loose and make noise. I have a bit of crap between the disc and the hub. I don't have spacers though but I would have thought they'd make any problems of this sort worse.
We have this too & it turned out to be the rearmost bolt that holds the wishbone on to the subframe has elongated the hole in the subframe... a common fault apparently- tightning up the bolt cure's it for a while but I guess it will need welding up.
