fUbAr Jan 30, 2007 #1 When i turn to the right there's a knocking/banging noise from the N/S wheel. it does it when moving and when stationary. ive just replaced the shocks, springs and top mounts... any suggestions?
davebem Car Lots of Alfas Jan 30, 2007 #2 Ive got a similar problem except when im moving, mainly on roundabouts, I think its my driveshaft cv joint. Having a look at the weekend.
C C.slicker Car Breaking A 172 Replica Jan 30, 2007 #3 Check the wheels are on tight. Also have a look under car to check CV joint rubber is not split. If it is the joint will be dry.
fUbAr Jan 30, 2007 #4 okie doke... thanks for the replies. if its the cv joint is it a cheap fix? will it be obvious if its gone?
davebem Car Lots of Alfas Jan 30, 2007 #5 If it is you need a whole new driveshaft, you can exchange your old one with renault for about £90 I think.
L Littleleigh Car Clio 1.4RT Jan 30, 2007 #6 Iv noticed a nocking from my offside wheel when turning left, and powering through the corner, lol Same thing? Bushes?
