Ktec ik help!
Car  Ph1 172 (titanium)
Need to whip my filter off to clean it. I don't know where the original fitting instructions are. All the tools are at my mums. So need to pick them up at sometime. Someone give me a quick list of what I need. To remove everything. Save me a bit of time.
Thank you
T30 torx, 10mm and 13mm sockets and extension. 5mm Allen key. Flat blade screwdriver. 8mm spanner.
Take the battery out for easy access.
Cheers dan!
Was going to just take it all out. Is overdue a clean. So will inspect the whole lot. Will probably be easier if I just whip it off from the tb anyway. It's all fairly tight in there.
Priceless. Don't forget to keep breathing in & out while you're doing it.
:lolup:
