KTR de-cat pipe + standard exhaust
Ive got a 16v clio 100% standard at the min but im wanting a de-cat pipe
does the KTR de-cat pipe fit on the standard exhaust system?
if not is there any other de-cat pipes which do?
also can anyone recommend any good coilovers which can lower my clio about 80mm with full damping adjustment?
cheers
dont think u can lower a valver 80mm mate???65mm at the rear is about maximum i think although dont quote me on that. Why u wanting to lower it that much?Itll look good but i would expect the handling to be quite poor.
Coilovers; avos and leda.
pete
i dont wanna lower it 80mm i justwant the freedom to do whatever i want
do you get coilovers for the rear torsion bar too? ie coilovers all round? or just the front then get some uprated adjustable shocks for the front?
whats the max u can lower the front of a valver clio on standard wheels? without serious problems?
with coilovers im pretty sure u get front and back shocks so u would be able to adjust the bak, only takin a guess though!
the max ive known someone to lower is Scott on 80mm!
