KTR SHORT THROW QUICKSHIFT GEARLEVER
  Shed.
^^. apparantly theyre easy to fit, how easy ? are there any instructions, guides to follow for it ? Also, i hate the look of it, is it possible to wrap the leather back on it and also add the origional clio gearnob ?
Ali
  V6, Trackhawk, GTS
I love the look of them! Had mine for over a year! I got a garage to fit it...Couldn't be arsed doing it...You need a ramp really.
I think they look mint, if I end keeping my 1.2 16v I will definatly get one. The standard shift is like stirring a bowl of porridge.
  Ultra 197 ex 172 Cup
very easy to fit, undo the center exhaust / cat joint, then remove the heat sheilding where the gear leaver it, then undo the gear linkage, then the 4 bolts holding the present gear leave in (plastic lump, the gear leave will drop down with the plastic, take it to your bench, fit the new leaver, then bolt it back up.
  Shed.
Its as simple as that Folks ! :eek:
.....on that note, ill get a garage to do it lol. I know the standard is poop which is why i was asking about this one, i can imagine it been very positive and slick. No lumpy porrage bowl stirring type stuff. (Lol Alex :rasp: )
