Kwik Fit offer 4 x 195/50/15 Yokohama AD08R *£238 fitted*
JamesBryan
Aye, these will now be my road and wet tyre replacing the Rainsports. Should be a much better all-rounder to use when I can't use the Toyo RS1's.
They're not too bad in the wet on track really. Only when the tread depth starts getting really low do you start moving around a bit more.
The standing water you get on in the inside of Old Hall at Oulton in the wet is fun with about 2mm left 😂
Ol’ Tarby
  Clio 220 Trophy
All 195/50/15:
2 x Avon ZZS with about 2-3mm £30
2 x R888 with various tread across the tyre from 0.5-3mm £10
2 x Rainsport 3 with around 3mm £10
Ahhh assumed you might have a matching set of summet. No worries mate
