Lambda sensor wires
  Clio 182
i had the car up on the ramps at the garage today and the connectors on the lambda sensor was hanging down
as the engine light is on i suspected the lamba sensor when i pulled the connectors apart the insides were all corroded
where can i get some new connector from ?? car is a 182 54 plate i will be putting a new sensor in so will need the male that clips into the female one on the sensor
thanks
you can't get hold of them, I've tried several times. In the end I've cut off both sides and fitted a superseal type connector
