No idea Tbh mate, not sure if the Jon Foz xlow frames have mounting points for the inner?Where are you mounting the inner lap belt?
Seen them, so you just bend them to where you want? Could use one for the outer as well?You could use a Schroth B23a bracket like this
Would the above not be a bit short? Read on here you need at least a 40mm for the outer bolt as the OE one is quite long? Will go to the car tomorrow and pull the belts out and see. Nice one for the help as well mate.Yeah mate, just put it under the bolt that holds the subframe down, with a decent washer on though.
I'd just use the outer bolt hole where that belt rail was and screw this in
Can't wait to get my MSV cage, OMP 4M 3" harness and Corbeau Clubsport XL in for Oulton on the 4th of March. I'm having track day withdrawal...
Yeah mate the rail bolt, if you've used the 25mm then I'll go with that, nice one.You are on about the hole in the side where the lower belt rail is aren't you, not the floor pan?
We ran the normal 25mm ones on my mates Clio. Don't know why the standard bolts are so long because the threaded bit in the body isn't that long...
