Leak....advice needed
Car  Clio 172 mk2
My car has developed a small leak and I'm a bit concerned it'll get worse over time.
The leak is coming from a sensor at the front of the engine which appears to plug into a solid bit of piping for the ac or power steering.....not sure which though.
Can anyone confirm what the sensor is for and wether it's easy to fix?
Probably just the rubber seal thats broken, should be able to buy that seperately.
Pretty esy to see really....just look below the fuel rail guard and you'll see the sensor plug.
Doesn't leak loads but always has some fluid on after a run.
