Leak is getting me wet
My clio has a leak which fills the inside of the passanger cill plate up (not the cill the bit between the cill and the car) then when i drive i can hear it slushing around then if i brake hard it comes into the car .
anyone any ideas
The exs used to slosh water around in the passenger side sill - I think you need to get on your knees (oo-er) and check the drain holes are clear. (Think they are at each end?)
will do, had a look rarlier couldnt really see much the water comes into the car through a hole situated up above the glove box where the wire harness for the door goes through the inner panel,
the car smells like when you was at school went on school trip and left half eaten food in your bag for weeks, well i will take a look later today
the grommet on the bulkhead has probably fallen out. Take the plastic trim bit off from under the bonnet and have a look. At least the ecu isn;t having a bath which they usually do.
