Leaking side window
  182 (Conversion)
Hi guys, learning a lot but can't find anything on the search hence the new topic.
Side window (not the door window) is leaking a little tiny bit as it's been replaced due to some accident damage (before I bought the car). It's not bad, but around the top of the window as it starts to curve down it appears that some "sealant" or whatever is used has slightly come away/separated leaving a tiny gap for water to drip in.
I want to get it fixed more to prevent rust but a leak is a leak and I want to fix it. Any suggestions? I was thinking a thin amount of clear silicone injected around but wondered if there's a proper way.
Thanks,
Rob
