Leaking sunroof
Car  Monaco 172
proceeded to sit on the divers seat...and receive a soaking arse! is it more likely to be the big seal at the top or the seal under the bracket? the big top one is slight ripped and work and a bit shagged. but just wondering does this actually stop water run through and come out just infront of the sun visor or is that the one under the bracket?
pete
haha the leakin sun roof.. ive just fixed mine.. Mine was the same as urs everytime it rains... wat i ended up doin as i hardly ever use mine is dry all the seals off and fill it with silicone... put loads on close the sunroof wipe of excess... and pow.. no more leakin :D
you got a mk2 ph2 by the looks of it pete i would say check the drain tubes push down on the roof along the egde of the sunroof frame if it opens to a gap then it the frame at fault
hmm i like mine, sad maybe but i do use it lol. em the seal ive ordered is 63quid..not cool. and the whole frame is nearly 200 apparently. hope this new seal fixes it though im gonna take it off later and have a look.
A possible is that the leak is infact coming from the airiel if you have a mk2. its a common problem if you have the pre- facelift with the airiel at the front. this is a common problem with the clio. if so take the panel with the light off(infront of the sunroof), unscrew the bolt at the foot of the airiel pull it off from the roof of the car and put some sealer around the hole, put it back and tighten.....HAPPY DAYS!>worked for me anyway
