Leaking water :(
Car  clio mk2 1.2 16v
My 1.2 dynamique has just started leaking water just at the top of the A-pillar on my passengers side, I noticed part of the windscreen seal has started to come away on the outside, is this the problem or is it a product of a bigger problem? :(
cheers for any help
does it have a sunroof ? if so prob be sunroof related check your sunroof drain tubes under front arches check there not blocked
I've discovered this problem too, how would I go about checking the drain tubes?
