LED Sidelights
Car  RenaultSport clio 172
I installed some LED Sidelights to my 172ff a while ago to complement the Xenons, only now one decides to flash (so i look like an unmarked policecar)! I had a fiddle with the wiring and couldnt stop it so have now reverted back to my standard ones. Does anyone know why this has started to flash?
Its the resistor inside, they vibrate apart.
Buy PIAA ones the last longer.
what I don't quite get is how they can last such little time. I had a set that lasted less than a year, which means that my current "normal" bulb last more thant 4 times the time of the LED. The LED is supposed to last longer than bulbs. Now I understsand that it is not the LED itself, still not good enough.
I wonder if the technology for all those new LED lights at the back of cars is any different, because I woldn't be keen on changing the electronic regulation every year ir so.
I had the same problem with these led sidelight bulbs gad 3 sets in 2 months, gave up in the end not worth the money there printed on. But i must admit they do look good!
Thanks Paul J, have you had any experience with these bulbs? Are there any precautions to take to make sure the new bulbs are in the right conditions?
They really do make a difference
Ive tried quite a few and in several vehicles. The Clio is really bad due to heat from main bulb, this can be tolerated by those posted. As the article says, avoid contact particulary when hot and dont insert deeply into socket.
The only other thing LEDs are sensitive to is voltage but so long as your alternator/regulator is working correctly this isnt a problem.
