I'm trying to do a dash conversion. Using a 0.2mm solder and i cant for the life of me get the old led's out! Any ideas? I dont want to risk applying too much pressure or damaging the board.
Add some solder to the joint FIRST, then using your tweezers lightly pull up that side....then move to the other side...add solder to the joint and pull up that side. Repeat until the LED is off.
