Homo spec mazda
Hi guys, Basically my car has just had a new front and rear bumper fitted due to getting rear ended and pushed into another car, Since ive had it back the left number plate light was out, So today I went to change it, As I've pulled out the blown bulb, the other number plate light went out, as did the left tail light, and the left side light.
Called the AA out because I was feeling lazy, he changed all the bulbs, nothing, checked all the fuses, nothing, reset the ecu, nothing. The weird thing is the tail light is the same bulb as the brake light, which works, as do all the other lights in that cluster.
And just to make things worse, put my wipers on becuase it was raining, and they have started resting higher up then usual.
Any ideas peeps?
Any ideas peeps?
