LIGHT
It is your coolant temp warning light...
The book says:
If this lights up when the vehicle is being driven, it indicates that the engin is overheating. Stop and allow the engin to run idle speed for a min or two. The temp should drop, if it doesnt allow the engine cool before checking the coolant level. Call for assistance of Renault dealer if necessary.
car wasnt startin b4!!!?? was doin this on thursday, coolant is jus below max, anyone no why??
Could be a load of reason most common problem is the TDC sensor failing.
The book says:
If this lights up when the vehicle is being driven, it indicates that the engin is overheating. Stop and allow the engin to run idle speed for a min or two so that you can let the engine temperature climb even higher, guaranteeing damage will be done. The temp should drop, if it doesnt allow the engine cool before checking the coolant level. Call for assistance of Renault dealer if necessary.
lol
