lights on dash need HELP
Car  clio 172 cup
hey guys im new on here as ive just got my clio sport but... the oil level light is on and ive checked the oil and it is fine. serv light is on and airbag, can anyone help me please??
The oil light is for pressure. If its on, then the oil pressure must be lower than it should be. Serv and airbag lights can often be solved by checking the plugs under the drivers seat.
Oil light - Clean the connector on the level indicator. (the one that goes into the block next to where the dipstick goes in)
Airbag light - Cut out the grey and yellow connectors under both front seats.
no no no no no no no no.
Do not just cut them out. They need to be re connected a certain way. There is a guide on here iirc, but you need to join.
Try wriggling the wires under both seats first , before cutting them . Mine came on , i wriggled the wires under the passenger seat , problem solved.
You don't need a sledge hammer to crack a nut ;)
found out the serv light is on because of airbag light and oil light must be the pressure because it only comes on when i drive. is it still safe to drive like this?
probably not, mate. I'd get it looked at. It could simply be the pressure sensor thats gone, or something more serious. Is it leaking any oil, or consuming any at all?
no not leaking any or using any. im goin to have a clean at pressure sensor, is it the one that goes into the block next to dipstick
