Ktec sell an alloy crank pulley now, I noticed it the other day. I suppose it's just like getting a lightened flywheel. Less rotational mass to spin so better efficency.
lightening rotational mass is all well and good, but removing a harmonic damper is a bad idea. I've seen engines knock out main bearings with the non damped resonance you get. Also if you look at balancing data, you will always find the flywheel end will have a greater degree of unbalance. all you do by lightening the pulley end is widen the error, end to end. No need, no benefit, no bloody point
Cool, well I may give that one a miss then. Just thought I'd get more power at the wheels if I did so but by the sounds of it I'll just start breaking things.
reducing rotational mass doesn't increase power, it just gets you there quicker, reducing friction increases power (when talking reciprocating/rotating parts)
