little help please.
Car  AUDI A5 s-sline
Does anyone know how to take off the front badge i cant seem to b able to get in to take it off.
or remove the rear clio badge to spray it! :'(
help please :D
front one just comes of.. give it a good pull!!
rear one needs the protective cover to come of within the boot lid and you will see the 2-3 bolts to take of teh boot button.. then you just unclip the badge
thankyou iwil try asap ! :P
but wanted to know about the word '' clio '' badge is it on clips on is is stuck on
?:approve:
o ryt ok wel tried taking the '' clio '' badge off, was slowly coming off but on the 'c' and 'o' underneith i could just c there was 2 little black things, does anyione know if there sticky pads or clips??? :)
o great! :(. does anyone know how to get it off without doing damage to the car or badge? also can someone help me how do i get the side strips of do they push of or do they need taking off from the inner of the door? cheers:)
No offence but the way you post is painful, no caps and no paragraphs, this makes it very hard to read... (I have demonstrated this below out of boredom)
Your "clio" badge sounds like its clipped on, it should still just clip off, I personally use a screw driver wrapped in electrical tape/a bit of rag to do this sort of thing. Just prise it off. You won't damage the car, and at worse, damage the badge clips, badges can be picked up for peanuts.
Side strips push inwards, so if you open the door, push towards the middle of the car, so the front one pushes towards the back and the back one pushes towards the front. Once they've moved a bit they'll just pull out, they sort of clip in.
Painful Version:
no offence but the way you post is painful, no caps and no paragraphs, this makes it very hard to read. your clio badge sounds like its clipped on, it should still just clip off, i personally use a screw driver wrapped in electrical tape/a bit of rag to do this sort of thing. just prise it off. you won't damage the car, and at worse, damage the badge clips, badges can be picked up for peanuts. side strips push inwards, so if you open the door, push towards the middle of the car, so the front one pushes towards the back and the back one pushes towards the front. once they've moved a bit they'll just pull out, they sort of clip in.
See how much harder that is to read?
thanks for the reply mate will get going on it asap! :P.
sorry about the whole english thing never give it a thought, dint realise i was in an english exam :P. haha just kidding.
