location of the washer fuild pump on 172
Car  clio 172,astra 1.6, rs125
As above could some0one tell me where this is as its stopped working!
adrian
Open the bonnet mate and its below where you top your washer bottle up on the right hand side at the back.
Remove the scuttle panel and you'll see it/them in the side of the tank. Dead easy fix.
As above, its a little fiddly to disconnect everything. when you take the pipes off the pump your car will piss all over your garage floor.
But only if u tickle it too much whilst disconnecting.
Plug it with earwax and crush a beer can on your head, this seems the most effective way of completing the 'ruprect' image whilst holding a water bottle thats leaking all over your feet :D
Take the motor apart and it's an easy fix, the bar that moves side to side jams.
