loom pins ....
Car  Clios
Hi all.
Im currently in the process of making a loom for my car and im going to be repinning the plugs as to trying to avoid the use of solder where possible.
As such i'm needing to buy new pins for the plugs.
Can anyone tell me where i might get pins for the rear lights? or the name of them as theyre obviously quite odd.
I'm also needing pins for:
fuel pump
headlights (all plugs)
rad fan
injectors
gearbox plug
starter motor
alternator
Basically everything.
If anyone has any info on where i could possibly get these then it'd be much appreciated!
thanks
Foz
Hi all.
fuel pump
rad fan
injectors
gearbox plug
starter motor
alternator
thanks
Foz
RS components if you know what you need.
https://uk.rs-online.com/web/c/conn...-connectors/automotive-connector-accessories/
