Clio 1.4 Ph2 Extreme
Hey,
right.. ive been looking at fitting rear speakers in my clio extreme..(dont have rear speakers )
I had the radio that i put in out again (alpine HU with ipod connection)
It has the stalk adapters so i can control it via those.
I have a sub and amp in the boot running off the preouts.
I still have two preouts on the back of the HU iirc
I was thinking about first getting speaker wire to the rear and putting standard speakers in then when i find some nice components put those in (might be a waste of time putting the standards in??)
But checking the loom from the radio looking at the rear speaker wires and following them from plug to plug and there are the wires for the rear speakers that go on the furthermost plug for the radio I.E too all the speakers and battery etc.
But following them back there appears to be no cables of the same colour and stripe pattern at the large plug on the floor next to the bonnet release and none at the back where the cable would split to go up to the rear speaker.
Is it best to find the existing wires in the radio plug cut and put new speaker wires in.. and then feed to rear speakers left and right. If so what type of speaker wire should i use if im likely to get components within the next few weeks or keep them standard?
And if i wanted to get 4 components 2 front and 2 rear then would it be best to amp them first using the spare 2 preouts on the back of the HU and to a separate amp in the boot.. Would i need to bridge amps or get a multi channel as my current one is only a 2 channel one...
Any help on this would be much appreciated, i hope it makes sense. Thanks Liam
