2002 Clio 172
Hi there,
I recently bought myself a 2002 Clio 172 and on my way home from work today I suddenly lost all drive and rolled to a stop. The problem details are as follows:
Engine still running fine
Can still select gears (not just gear linkage disconnected)
In gear with clutch up the speedo registers a speed even though the wheels aren’t turning.
As the speedo registers a speed I am assuming that is whatever links the driveshafts to the gearbox that have broken? Which side of the gearbox is the clutch on, if it is downstream of the box I guess this could be a clutch failure? Any ideas or help would be appreciated.
Alec
Alec
