Lost reverse after fitting a new clutch
Car  clio campus 1.2
Car : Clio 2 Campus 1.2 2007 - D4f
just fitted a new clutch (pressure plate and thrust bearing)
to get into 1st I have to lift the reverse gate. Then it goes through the gears fine. Down shifting from 3rd to 2nd I have to lift the reverse gate again.
can’t get reverse at all
must be linkage related? But I disconnected from the sleeve style joint marking it before removing and install on the exact same spot
anyone know what might be the fix. Thanks
Itll just need adjusting on the sleeve. It's such minor adjustment has a huge effect higher up.
Remove the bolt connecting to the linkage next time on the box.
You didnt drop the subframe onto the linkage either did you? Seen people bend them thay way before too
Yep you’re right about small adjustments making a huge difference. I rotated it on the sleeve less than 1mm and it’s all sorted.
