Seriously? I can't afford that. Is it ok to drive around with them like this for a while or is my wheel going to come flying off and send me careering into the back of a bus full of school kids?
I'll get those fitted for you no bother for a lot cheaper than a garage.
Contact G172 on here, he's a brake dealer on here. You want rear discs with ABS rings and bearing pressed in. Sorted
If you can't afford a pair of discs and bearings when needed, you really shouldn't be running the car then TBH
What's gonna happen when you need two front tyres? Run them down to the bones and then buy part worns?
Buying a bearing is a massive false economy.
Considering you can get discs and pads delivered for about £100, buying 20 odd quid worth of bearing, then having to pay a garage to press out and then press back in is going to work out the same pretty much, if not more.
Just bought them! Cheers for the link Rob! If you're about in Laindon I could come and meet you somewhere or by all means come round to mine and il make you a cuppa/give you a can of fosters haha
