loud humming at all speeds from front of car
  clio mk2 75 vw bug
Hi I was wondering if someone could help I have a 1998 clio which is makeing a loud humming noise from the front passenger side of the car while driving it can be heard at all speeds but gets louder the faster I go, itmakes no difference if I coast the car the noise is still there, I dare not take it over 30mph as the noise is so bad also the car pulls a little to the left but not excessively, i have jacked the car up and put it in first gear with engine running and a clicking/scraping noise can be heard as the wheel rotates, any help would be greatly appreciated, aldo all tyres on the car are good
Sounds like a wheel bearing, very possibly the gearbox but hopefully a wheel bearing as its cheaper to fix.
Spin each front wheel, the one that sounds the worst will be the one which needs the bearing replaced.
  clio mk2 75 vw bug
Hi thanks for reply forgot to mention if I turn left hard it stops making the noise until I straighten steering wheel up or turn right
Do the tests and see if you can rule out what it is, if it is a bearing the fronts are pressed into the hubs which you will need a press for i.e. garage job or source a second hand hub and have a new bearing pressed into that then change it over.
That's if it is the bearing.
