Loud rattle
Jimjam930
  2002 Clio sport 172
Hi everyone, I had all the belts and dephaser done at rensport a few weeks ago, and on its first time out it developed a quiet rattle coming from the drivers side engine bay, both I and rensport were concerned so I had it trailered there. They said they found a bit of plastic near the powersteering which was causing it and found that had fixed the noise and problem. I drove it home and on exiting the car I found the noise was still there. I decided to leave it for a few days and contacted rensport about it. I went to start the car today and the noise is much much louder and instead of only happening when warm it happened immediately. Does anyone have any idea what could be causing this? I've attached a video of the sound.
Thanks,
Jimmy
Jimjam930
  2002 Clio sport 172
Hi mate! Did you get it sorted? Mines also making this same noise.. 😔
Hi mate I did in the end yeah, turned out to be the clutch release bearing, if it goes away when you press the clutch it'll most likely be that
  clio 182
Aw thanks man! That would make sense! I’ll check it out in the morning,thanks for replying 😃👍
