low rev stutter- ideas?
  53 Clio's & counting
well i noticed this morning my cars got this missfire/stuffer under full load but only at low revs, (under 1500 revs) then it will clear, funny thing is it only does it in the 1st 3 gears, any ideas what this could be chaps?
plugs and leads are around a year old so cant be them
MattRS182
  #3 PH2 172 Flamer
my old 1.6 did this!! never got to the bottom of it, only did it mornings thats it haha
iv been looking for prices,anyone recommend anywhere apart from Renault to get a lambda probe from? (i understand its the front pre cat one that matters over the post cat?)
  lift number 1 @ btm
i've got one from a 182 at tim's. but i'm not sure if it will be any use to you. don't they have four wires instead of three?
you can have it if it is any use?
does anyone know if there the same guys?
Yeah cheers Doug, il give it a try!
MPG has gone down too on this tank chaps
lol no mate, had the filter out a few weeks ago,still pretty clean
its so weird, just pull away real low revs,bit of throttle and it sounds exactly like it overfuels, then by 1600 rpm or so it clears
thing is my mpg has suffered,been getting 340 miles to a tank, this one isnt going to make 280 :(
Christopher
  Z4M
Ah yeah, mine was early 2000.
As far as i know, they're the same as a 182's lambda. Although i've never actually tried.
Good luck getting it out though... ;)
ok this morning things have changed lol, it now missfires throughout the whole rev range, but only under load(over 1/4 throttle) if you raise the revs slowly it wont missfire :S oh and the engine warning lights keeps randomly flashing, oh the fun!
any ideas?
  Monaco Blue 172
did you ever resolve this? my car's been doing the same thing, when accelerating sharply from low revs (3rd/4th gear, <2k) it stutters before pulling away. To be honest it sorta has been doing this since I got it 4 years ago (!) but problem seems to have gotten worse recently. i've got a prospeed exhaust with decat but then put the cat back on as it was way too loud for mway driving. not getting any warning lights though. advice please anyone. my bf reckons valves need adjusting but that sounds like an expensive waste of money on a >140k car!
cheers
