Where can i get one of those thermastats for a valver that make the fan come on earlier and how much? I thought K-tec do one but i cant seem to find them on the website?
bbperftuning, link at top of page, piece of piss to fit, remove hoses to housing, undo torx bolts, put new one on, and refit housing with a little instant gasket, worthwhile, I have one on mine, hope that helps
havent done mine on the clio but a thermostat will be easy to change, just take off the cast and it will be sat there - halfords replacements usually come with a few gaskets but if they dont then instant gasket works fine.
its will be obvious how it goes in when you take the old one out and see the new one
I decided not to fit my low temp thermostat, as a number of mechanics, including a Renault one said they cause problems. ECU adjusting the fueling cos it doesnt think the engine has warmed up.......
the ecu would only adjust to the to the coolant temp it reads.cant see you having any problems.if the ecu etc is working ok then the engine will run fine no matter what temp the engine is.
