low temperature termostat for 172/182
  RSTUNER'ED-C&B'ED RS-1
low temperature thermostat for 172/182
Does anybody aware of a low temp thermostat for Clio 172/182?
not a chance for me, but I come up with a solution, if you buy RSTUNER pro, Henk can set rad-fan trigger temperature at any value you want. He did it for me. But again watch out, there is always a min operating temperature for an engine in order to run efficiently.
And what would this min temp be ?
  F4R'd ITB'd '92 cup racer
i would like to know this too :)
or if someone can tell me what temp the fan kicks in as standard?
  TVR Cerbera
I can do that anyway cos i'm running an omex. I need the run the engine cooler because of the mods i have and therefore i need a cooler stat.
  Lots of Alfas
On a 172/182 the fan comes on at low speed if the coolant temp reaches 100c, (or will stay on constantly if the air con is turned on). When the temp gets down to 96c it will turn off. If the temp reaches 102c the fan comes on at high speed, then low speed at 100.
However I beleive the 172cup (without air con) only has a single speed fan so comes in at full speed at 99c and goes off at 96c.
stat - 89 C std
fan - 99 C std
I got different .cal files. For one, fan kicks in at 95 C.
  CLIO 182
i know it's an old thread just need some clarification will the fan kick in regardless of engine temperature if the ac is on? Mine seems to come on when the engine is really cold. It's had a brand new CTS and stat so no issues there?
