Lowering Brake pedal
Car  172 gravel rally
Is it possible to lower the brake pedal on a 172 by the brake servo control rod? The brake pedal is far too high at the moment and could do with being lowered 20mm
Whats the reason apart from making it difficult to heel-toe? I ended up raising the accelerator pedal but can't see what the problem would be of lowering the brake pedal.
brake pedal switch is the only reason i can think of
just wear wider shoes (skateboarding shoes are perfect) for heal and toe in a clio
