Lowering MK1 16v/Williams -50 rub?
Car  172
I have just got some -50mm lowering springs/adjustable absorbers for my valver. I am running Williams alloys with 195/45's, i just wondered if it is going to rub?
Thanks for the reply, so it won't rub? Also when i lower the rear won't it mess the rear load brake bias valve up?
If you widetrack the front I got a feeling it would rub, but standard 16v will be ok.
Bias valve can be adjusted if it makes 2 much difference.
-50....doubt you'd need to adjust the bias valve. but its up to you...
-50 wont rub what so ever....
