not a problem but the spacers you use would have to be mm perfect or you car wont track staright, i would get some longer bolts too....
why would you want to anyway, mad engine conversion planned????
Why are you doing this pat??
i have dropped mine by 6mm, i had four spacers made and drilled, i used longer bolts, no issues with tracking,camber, caster etc. handles ok too![]()
Where is it rubbing? I've got a good 10-12mm clearance between the 172 mani and the subframe. :S
Surely they're the same?
ive got about 2mm of clearance on mine :/
I have already raised the engine mounts 5mm and I dont think I can raise them anymore because of the bonnet!
Nightmare!
