Lowering problem again.
Might want to put that bolt back in. Why did you take that out anyway? You can get the springs out without undoing the shocks lol.
But the back on axel stands on the mounting points, the rear axel will drop down. Loosen the top of the rear dampers from the TOP. Don't undo them and they'll pull out. TBF, you'll only need to loosen the drivers side damper due to the wheel well. The passenger side will just pull out if your a man.
Basically that picture with the bolt half out.
I lowered the back, ran out of time so did the bolts as tight as I could do lol and I drove to Medway and back, next day Adam goes to tighten them more and sees this lol!
Woooooopsie..
