Lowering
lol if i find out mate i will. I duno wats diff between the springs and the lowering kit which is like 5 times as much hmmmmmm
same but i would guess that put lowering springs on standard dampers isn't gunna do either of our cars any gd might last couple of moths b4 they give-in, guess theres a reason the kit is so much more expensive
just the springs if your gonna lower it between 30-40mm
anymore than that will damage your standard shock absorbers
real shame cos im desperate to lower mine but don't wanna kill it in the process as i don't have another £300/400 quid to fork out for a whole new kit
see above
o ok cheers for that dat sounds alrite might give it ago any one know how hard/easy it is to fit new spring and if 30-40 mm lower will make a visual difference
do a quick search or post a pic request in the pic section, sure someone will have some pics for you
Had my car lowered by k-tec for £150 with springs took 45mins!
so is it a bad idea to do it with just the springs yeah is it dangerous too. What u rekon for a full set then on the cheap.
Springs are absolutely fine for 30 and 40 drops, anymore and a full kit would be the best bet.
