lumpy/misfiring
  172 sport
Ive just gotten a clio 172 rsport on an 02 reg and as the title say it runs slightly lumpy and feels like its misfiring on idle....is this a common problem with these cars....do they tend to run lumpy??and suggestions welcome..
  Skoda Fabia vRS
is this only happening from a cold start in the morning ?....or all the time ?
apart from idle how is it running in the rest of the rev range as your driving around
  172 sport
no when the engine is warm it does it too.....seems to be ok whilst driving
  Clio MkII 172 K reg
You may hear the misfire if you open the bonnet and listen. I had it when bought mine. At first repalced plugs but the problem not cured. Then repalced plug leads and the misfire ended.
Also, do you feel loose of power at any rpm ?
  172 sport
misfire is more noticeable whne im in the car listening to it.....might change the plugs and leads and go from there.
ive only had the car 1 day so i cant say if ive lost power
  "Navy" N17 TWO
A 172 i was in the other day sounded a bit lumpy or "hunting"
Is this common when they are cold?
