You need any optical cable and an optical to SPDIF adaptor, about £2 out of maplins, don't need to spend a fortune on the optical cable either. £5 optical cable + SPDIF adaptor.
Then Mini DVI to HDMI for the video. If your device does not accept optical audio as well...then things get a little more interesting and a lot more expensive. As you will need something like this.
Just get the mini display port to HDMI along with the 3.5mm as Tom said. It's what I've done and it's a lot easier than *****ing about with all the digital shite.
All well and good saying that...just what happens if his TV will only take audio from the HDMI socket. Then he has video and no sound. Unless he has an external amp that will accept a 3.5mm jack (Most don't) He will then need a 3.5mm to phono and then need to connect that to the amp. Just more messing about.
I know my TV does not have a 3.5mm input for audio. It's HDMI or nothing if you are using a HDMI video source.
