To do any proper correction on anything less than very very minor marring I would expect you to end up using the 83 on a cutting pad if using a D.A type machine.
his paint work is quite good with only slight swirling. probily abit late, but id try the light cut polish on the heavy pad, then finish with the light cut polish on the finishin pad.
