Machine polishing
Car  Fabia VRS
Hey i been looking on here bout machine polishing and that it can take out swirl marks. i mentioned this to a mate at work who said he got given one as a present and never used it and said i could have a go with it. my car doesn't have bad swirl marks so would i get away with just using auto glym super resin or is it going to need more than that? Also its only a cheep machine from halfords, problem or not? Any help would be ace!!:)
Halfords machine if it is the one I think it will be will not be up to doing any paint correction or swirl removal !
If its the one i'm thinking of, it won't even remove Fastglass!!
The Halfords jobby probably wont have much cut. The Pc/G220 are random orbital polishers which mimic hand movements but faster whereas the Halfords one goes in circles iirc.
It may be ok to apply SRP with but i wouldnt expect massive improvements in swirls, due to the machine and SRP. SRP isnt very abrasive but still a very good polish and will give a good shine on RB(more of a concealer rather than a demolisher). To remove swirls you need a decent machine + more abrasive(ish) polish. If you cant see too many swirls, ( best to see in direct sunlight or petrol station) then use SRP. I still use it as it is a really good polish and does hide a few swirls.
btw please keep RB pics to a minimum as i miss mine, when it is clean it looks soo nice tis a shame RB isnt very photogenic
Thought that might be the case. cant afford a porter cable thingy atm.:( The swirls are't bad only slightly noticable when the light catches um. will they come out by hand polishing? i got some of that new autoglym high def wax that seemed to make them a bit less noticable.
SRP wil hide them a tad, If you want to work your Biceps then use Megs Scratch X in small concentrated areas. Where are you in W. Mids i can have a little look?
Worcester area. when i got my RB i thought i was like the only one in my area then loads started popin up. lol. so coz im not modifing it wanted to keep it super clean!!:) i think ill save up and get decent machine polisher later in the year. the colour does look the dogs all cleaned up!!
Only problem with machine polishing is that it takes alot of time after you set everything up. Just use SRP properly ( go to detalingworld) and you will get good results. Never see any RB in worcs just the same Black/gold with stripes!!
Lol im always looking out for RB's. cheers for your help. :) Wat Mk's your vee? ill keep a look out
Riz got banned from Worcester IIRC something to do with a small dog, nakedness in a park.
