main beem xenons
  clio 172 ph2
ive installed xenons in my hi-beam. when i put my normal low-beam xenons on the green and blue headlight indicators come on in the dash as if the blue one is getting back-fed frem some where.
it seems to be something to do with the driver side light unit because when i put standard bulb back in that side, all is well!
its been like that for 2 years and does not afferc any other electrics, just wondered if there is a cure or is the only way to stop it is to put them back to standard halogen?
  Ford Transit
I wouldnt recommend converting your main beam to Xenon HID. Simply because the technology behind igniting the bulb, it takes roughly 10 seconds for the average xenon hid kit to ignite and reach full brightness. When you flash someone thwe ballast and bulb only get the power for a split second not giving the ballasts time to do what theyre meant to do. This is return can damage both the bulbs and ballasts and not only that doesnt do the job your intending to do "flash someone". Using as a main beam is fine as I take it when you switch it to main beam your going to leave it on that beam for longer than 10 seconds.
Nathan
