Mainfold to cat fittings.
  RRS, 172, ST3, VTS
Hey, i need the part number or description off the part needed for the manifold to cat fitting, i couldnt get it from renault. I have the bolts, spring etc, just need the actual bit that sits into the manifold itself.
As you can see from the picture the sorta insert bit is free floating, and if i tighten the bolt up, its not actually fixing itself to the manifold if you get me, the see insert bit you can see is just pulling right through the manifold.
  RRS, 172, ST3, VTS
CHEERS FRED, DOES THE KIT COME WITH THE INSERTS FOR THE MANIFOLD? I USED A LARGE WASHER TODAY JUST AND A LONGER BOLT AND NUT, ITLL DO THE JOB.
