Spark plug timesert repair?
bozothenutter
Well, mine did it as well, and yes, on #3 cylinder (and while checking the others, #1 didn't tighten either.
I have a Facom timesert set coming (tbh it looks like the cheap ebay ones....), but hey, who can afford the Würth sets? :eek:
I get the general principle, ( liberally grease the tap) but I'm still left with a few questions.
- The Würth set comes with a 'seat grinder/cleaner', is this needed? BGS do one.
- Some sites mention High temp threadlock for the insert, yes?, no? which one?
The Henkel site doesn't show all of them, and makes you go through all the datasheets seperately. Is resistance up to 230C enough?
- Would it be wise to do all of the plugs? There's not a lot of room to wiggle and check for movement.
bozothenutter
bozothenutter
muthafooking cars.....
attempted the repair today, it seems the tap wing in too deep, and now it's spinning without moving up or down.
Things tried so far:
strong magnetic socket
thick grease
pvc tube
This is the cutter.
socket size is 16
Would a set of long neck spark plug pliers work?
