mains cable / bulkhead
Car  R27 - 77/500
is there and if so a hole for me to run the mains cable to my amp ?
there is a load of sound proofing so dont wanna rip things open just yet.
also is it easiest to remove top of dash to run RCA lead to Head Unit?
ta
Use the bonnet release cable grommet it's a piece of piss. You need to unclip the PAS resevoir from the bulkhead, then you can get your hand behind the heat/sound deadening thats on it and feed it through the hole. I've done it on my 172 and my 182 in the dark/rain so it cant be that tricky ;)
Use the bonnet release cable grommet it's a piece of piss. You need to unclip the expansion bottle from the bulkhead, then you can get your hand behind the heat/sound deadening thats on it and feed it through the hole. I've done it on my 172 and my 182 in the dark/rain so it cant be that tricky ;)
The same way i do with a subtle difference!
