LY 200 cup full fat
Hi just had engine out and fitted a replacement as lower crank pully broke in half causing cam belt to jump so replaced engine ,belts ,dephaser pully,all the normal stuff while eng was out,all fitted up started car found fault on number 4 injector,so changed injector and started it up car was ticking over ok drove off ramp out of garage to test drive and felt a slight missfire,went to fuel up and car started missfiring more and also backfiring and popping through exhaust.No eng man light was on car seemed to not want to rev,Eng was timed up as it should be so can anyone give any clues where to look next,Changed sensors over from old engine to new engine no change,seem to have a good spark at the plugs
