manifold removal
Exhaust mani is a pain on the 182 as its a lot bigger than the 172. Theres a guide in the guides section.
the guide will give you a rough idea, its the same just a bit harder to get the 182 out and in due to space.
roughly....
unbolt 4 subframe bolts, unbolt the gearbox to subframe mount, unbolt the dogbone mount
remove the cat
lower the subframe down on a jack, undo the pinch bolt on the steering columb and the subframe will come down with a bit of a wiggle here and there!
it will need dropped down a lot to get the manifold out but it is possible, keep an eye on the PAS pipes dont want to stretch them!
^ Rough idea, fckin cheek! It's a farkin bible.
And i wrote it ;)
^^ as mentioned above and in the guide, keep a close eye on PAS pipes as the subframe comes down.
roughly....
remove the cat
f**k that ill get me coat:D thanks for the reply mate. very helpfull:D
