220 Trophy
I have turned my PH1 172 into a track car and removed the headlight height adjuster switch in the dashboard as I knew I would never need it again and also needed the space for something else.
I am replacing the headlight units themselves with identical OEM units as the old ones are a bit tatty.
My questions are: once I swap the units over, will I need to manually adjust the height of the new unit?
And if so how is this done?
Is the height adjuster actually within the unit itself, or is it the complete unit that moves up and down?
Thanks.
Thanks.
